40-420 Manifold/Muffler Question
jm
08-14-2001 12:58:48
I have a 1958 JD 420T. I am about to replace the manifold and muffler on my tractor, which are rusted completely. The manifold is the same manifold that goes on a JD 40. The only muffler that I can find for a 420 is the oval kind, which means I will also need to find an exhaust pipe with the mounting flange to connect it to the manifold. I have found a muffler for a JD 40 with a mounting flange on it that looks identical to the standard muffler for the JD 420. Can I use the muffler made for the 40? Will there be any problems with the hole in the cowling not being big enough? What about exhaust gas restriction, would that be a problem? Thanks.
G Taylor
08-15-2001 13:28:21
 Re: 40-420 Manifold/Muffler Question in reply to jm, 08-14-2001 12:58:48
From the factory the 420/430/440gas used a different head,ports & intake/exhaust manifold than the 40. A 420 manifold will bolt onto the 40 head but the ports will be partly mis-matched. An oval 430 muffler will help preserve the operators hearing.
mike
08-15-2001 04:13:20
The 40 thru 420 all used the same muffler,with
one exception,your tractor.The 1958 420's used
the same muffler as the 430,which was a short
round muffler with the extension pipe.The old
style won't work on your tractor unless you
make the hood hole larger.Any tractor supply
store,Farm& fleet,TSc,Farm&country, etc can
get you a muffler and pipe,or you can get a
more expensive one from JD.
Spokerd1
08-14-2001 15:17:46
Becareful of the muffler which you replace your oid one with. Some of the 420's used an adapter from the manifold to the muffler. I have a 420 which kept getting water in the oil pan, even with the exhaust covered. I had the head and block checked. No cracks. What I later found out that the muffler that was on the tractor , was for a 420 but had a smaller inlet than the other 420 muffler. When I ordered the adapter and found a Stanley muffler with the correct inlet, I do not have rain water getting into the engine. The adapter # is AT 10523 T and the muffler that fits that adapter is AT 3246 T. ( Oval Muffler. For the round , the adapter # is the same and the muffler # is AT 10646 T. There is about a 1/16" diameter on the maniflods to the muffler's. If you have the adapter you will need to use these mufflers. Even though AM 3101 T muffler seems to fit make sure.
