1938 John Deere G -SN 2542
Euclid Benoit
08-19-2001 11:20:23
I have my father's original tractor - J.D. G, and after installing a new head gasket and filling the rad with water, water poured out the four tappet guide holes into the crankcase as well as the tappet cover. I am a novice at this, is the block damaged or is the gasket?
Thks
Ron Stephens
08-20-2001 05:10:59
 Re: 1938 John Deere G -SN 2542 in reply to Euclid Benoit, 08-19-2001 11:20:23
Have a couple of NOS F55R head gaskets if needed. Would like $75.00 each for them.
Stephens Farms
Ron Stephens
3328 Rice Road
Dunkerton, IA 50626
319-822-7348
Euclid Benoit
08-20-2001 06:24:09
 Re: Re: 1938 John Deere G -SN 2542 in reply to Ron Stephens, 08-20-2001 05:10:59
Thanks, after reading the message from Deereheart, I may take a better look at the pattern of the head gasket and if it is suspect in design I will contact you to purchase one from you.
Do you know of an unstyled G for sale.
DEEREHART
08-19-2001 16:56:38
Euc. You did not say why you changed the gasket or where you got the new one. the last time I ordered an F55R from Deere they told me it was no longer available. the gasket after ser# 7100 is completly different. I ended up having a new one made. Hope this helps. DOUG
Euclid Benoit
08-20-2001 06:20:16
 Re: Re: 1938 John Deere G -SN 2542 in reply to DEEREHART, 08-19-2001 16:56:38
I bought the gasket along with many others several years ago and as I was disassembling the head to chek the cylinders and pistons decided to replace the head gasket since I had it. I had the G storeed for several years and had not run it in those years. I noticed water in the crankcase even though I had drained the cooling system years ago. I plan to inspect as far into the cavities of the block as I can. Any other advise is welcome.
