Front wheels on B styled
joe-tx
08-21-2001 19:25:05
I have a 1942 B styled. It has spoked wheels on front. I'm wondering if it came with those wheels or if they came off an older tractor.
Ferd Burful
08-22-2001 15:02:08
 Re: front wheels on B styled in reply to joe-tx, 08-21-2001 19:25:05
Could be steel wheels that were cut down and welded to a 15 inch rim. More than likely came off an earlier tractor as a 42 B should have pressed steel front wheels.
Will P
08-22-2001 21:14:45
 Re: Re: front wheels on B styled in reply to Ferd Burful, 08-22-2001 15:02:08
Steel wheels were avalible up to early 47.
Fred Farkel
08-22-2001 07:10:59
My 43B has spoked front where the round spokes are welded to the rim. The rears are heavy cast iron with a 38X12 rim.
Will P.
08-21-2001 21:40:22
Are they cut off steel? Are they factory rounds? My 43 B has cut off steel on it. Do the spokes look like they are welded to the rim?
joe-tx
08-22-2001 16:32:18
 Re: Re: front wheels on B styled in reply to Will P., 08-21-2001 21:40:22
They are round spokes and are welded to 16 inch rims.
Will P
08-22-2001 21:12:55
 Re: Re: Re: front wheels on B styled in reply to joe-tx, 08-22-2001 16:32:18
Those were originally front steel. The front steel on 40 and older (serial # 96000) have zig zag hubs. In 41 (96000) they went to a smooth hub. Your serial number for 42 sould be between 118721 and 136314. The YT mag serial numers are wrong. My 43 B has the solid hub and 16" rims too. Hope this helps. If not email me and I will send you some pictures.
joe-tx
08-23-2001 18:31:56
 Re: Re: Re: Re: front wheels on B styled in reply to Will P, 08-22-2001 21:12:55
I have a 43B. The ser. no. is 136847. I thought it was a 42B. The reason I wanted to know about the wheels. One of them is rusted out around the valve stem. I may need to replace it and may not be able to find a spoke type. What are zig zag hubs? Thanks for the info.
