1020 hydraulics
Steve
08-24-2001 20:01:37
Having trouble with 1020 JD 3 pt hydraulic system. Many times when you raise the lift the hydraulics chatter like crazy and when you put it down the pump continues to labor. Tractor has been meticulously cared for. 2800 hrs. Have owned the tractor since new in 1971. Any information would be helpful.
Steve
08-25-2001 10:37:21
 Re: 1020 hydraulics in reply to Steve, 08-24-2001 20:01:37
Thanks for the help. I have both service manuals and I will study them.
SmallOps
08-25-2001 03:06:58
Steve: I recommend finding the I&T Manual (JD-37) and using it for adjusting your JD 1020's Rockshaft. The adjustments are reletively easy to do because the I&T manual's instructions are made very clear.
Your's is one of those circumstances where the I&T manuals actually are more helpful than the JD Service Manuals!
As Illinois Red pointed out, there may be other repair and replace actions, but you will have to eventually do the 3pt adjustments. So, the I&T manual is a good $15-20 investment.
Illinois Red
08-24-2001 21:00:15
The rockshaft linkage might need adjusted, replaced, or you have an internal leak.
