1939 A temperature gage
Max
08-26-2001 18:55:48
Who knows?? Recently, I took the upper cooling pipe off for repair and removed the temperature probe that fits into that pipe- when removing that I detected smell of ether which was definitely coming from the sensor. Doesn't work now- worked fine before I took it apart. Does anyone know what is going on. Can it be repaired or do I need to find a new complete gage. This tractor is totally original so I want to stay original equipment if possible. Thanks in advance.
Russ
08-27-2001 07:16:27
 Re: 1939 A temperature gage in reply to Max, 08-26-2001 18:55:48
The line and sensor are filled with either, time for a new gauge. Russ
