1951 Model B ?normal? transmission noise?
Bob Weber
08-27-2001 12:00:00
I've recently driven the "B" that I got earlier this summer, and have noticed a little bit of a growl in 1st gear (no load, just around the yard). This being my first old green tractor, I really don't know what transmission sounds are normal. Should I be hearing any transmission noises at all, and if so, what?
Thanks!
Chuck
08-27-2001 13:27:28
 Re: 1951 Model B ?normal? transmission noise? in reply to Bob Weber, 08-27-2001 12:00:00
as you can see from my own posts that transmission noise is common. The only thing you can do, would be to tear into transmission. Some time ago, I built a B transmission and thought all the gears looked good only to have to tear it down again when I discovered a real howl in 1/3 gear. Just the slightest abuse, burring of a gear can cause all type of noise. I just discovered the same thing with my 530 and now am replacing some reduction gears.
