1944 B clutch styled
Steve
09-03-2001 13:25:08
I've broken a piece off of the clutch sleeve, the lip behind where the clutch fork rides. I'm thinking about welding the piece back on, its cast. Should I just order a new piece and press off the gear and put on a new one? I'm not sure if I can even get one from John Deere.
Thanks
Clooney
09-03-2001 15:54:42
 Re: 1944 B clutch styled in reply to Steve, 09-03-2001 13:25:08
Steve, welding that piece on is risky business. If it should ever decide to come loose it will probably end up in the reduction gears & that will definitely ruin your day! You should be able to find a good used one as there are plenty around.
Steve
09-03-2001 19:28:36
 Re: Re: 1944 B clutch styled in reply to Clooney, 09-03-2001 15:54:42
Okay thanks for the advice...
BB
09-04-2001 05:09:15
 Re: Re: Re: 1944 B clutch styled in reply to Steve, 09-03-2001 19:28:36
Steve: If you can't get one from you dealer, go to yahoo.com (or other search engine) and search for tractor salvage. You will find more tractor salvage yards than you can imagine.
