2010 hyd problem
Wendell
09-05-2001 03:44:05
power steering and 3pth refuse to work, they both worked intermitingly, pump is delivering 2000lbs pr. suspect stuck main flowdiver or reglating valve, this is 1960 so has the old style. just before it quits it acts like starving of oil but will not start again if shut down & restarted after a period of time any help would be greatly appreciated
Tim
09-07-2001 12:53:34
 Re: 2010 hyd problem in reply to Wendell , 09-05-2001 03:44:05
Wendell, replace the filter/ screen. I tried to clean mine with all kinds of stuff and it looked great, but it just didn't work. Without the screen in place everthing worked just fine. A new screen solved the problem. The hydraulics on these tractors isn't as bad as many people make them out to be, if there is complaining to be done the brakes are a good place to start.
Elton Fancher
09-06-2001 19:07:18
My 2010 has always had the same problems. Very often the steering stops working and I have to clean the filter. A new filter is $60, but it is worth the money. A rubber ring came off the back of the filter once and caused this problem. You may have already done this but if not it may help.
ben
09-06-2001 18:27:36
wendell. first check the hy screen right side trans below deck 3 bolts the screen is spring loaded you will need to drain the hy trans fluid the screen can be cleaned most of the time had one that even after soaking in carb cleaner wouldn't clean out had to replace it ben
