Basic Head Gasket Installation Question
jm
09-06-2001 04:54:22
I am installing a new head gasket on my JD 420T while in the final stages of my restoration. How do I install it? Do I just place it on the block surface dry, or do I need to put oil on the gasket? I wouldn't think I should use any gasket sealant but I really dont know. I would appreciate any advice. Thanks.
rollo
09-06-2001 05:20:09
 Re: Basic Head Gasket Installation Question in reply to jm, 09-06-2001 04:54:22
It depends on the gasket material. Newer gaskets usually have a sealing material coated on them and you don't have to soak them in oil. As a matter of fact, the oil won't penetrate the coating. If you have some old NOS gasket you may want to soak it in oil. If it were me, I'd use the spray copper colored adhesive you can buy in car parts stores, even over new gaskets.
Chuck
09-06-2001 05:02:15
I always use coppercoat, some use aluminum paint, I suppose it would probably seal if it were placed on good and dry.
