2010 rockshaft problem
Wendell
09-10-2001 05:29:45
My rockshaft is hunting to find a neutral under load , it will drop severe enough to bonce the front wheels off ground. I have adjusted load control valve from one extrem to the other. It will hold a load when the engine is turned off. I have had this assembly apart to clean out dirt ( silconseal), it is a possiblity something is out of adiust or a hyd leak, any help would be appreicated.
Lindsay Smith
09-11-2001 06:20:07
 Re: 2010 rockshaft problem in reply to Wendell, 09-10-2001 05:29:45
One of the most common faults I have found is the thermal relief valves leaking. If it is a rowcrop model there are 2 of these. They have a habit of leaking even from new. I now replace these from those used in JD 1020 and later models after adjusting the blow off pressure. Leaking ram seals cause similar problems as does wear spots in the bores. The valve adjustment is also critical although the fact that linkage does not drop with engine off would suggest one cylinder is OK. The model type would help as R and RU models are different. Of the 50 or so that I have repaired, the valve complaint is most common.You will need manual to make correct adjustments to valves.
