Servicing Hydraulics JD301A Tractor
jeltman
09-10-2015 07:18:19
When servicing the Hyd on a JD301A, is it filled via the cap behind the seat? Is the transaxle serviced separately or does the hyd fluid lube that as well? I found a dipstick on RH side for transaxle, looks like 90 weight oil, but could be Hyd fluid. Any help would be appreciated for this new JD owner. THANKS.
divewithme
09-10-2015 09:21:20
 Re: Servicing Hydraulics JD301A Tractor in reply to jeltman, 09-10-2015 07:18:19
If the 301A is similar to my 302A then you will fill from cap behind seat.
I use (NAPA Premium heavy duty tractor hydraulic & transmission fluid.)
Please note I said if your machine is same as the 302A
I to am new to this sight, the people here are a wealth of knowledge so I am sure you will get a more informed answer soon.
Tx Jim
09-10-2015 09:27:29
 Re: Servicing Hydraulics JD301A Tractor in reply to divewithme, 09-10-2015 09:21:20
90 wt trans oil is a death toll for brake pads on JD tractors designed for JD Hy-gard such as a JD301A
