55 combine... unloader auger doesn't turn
Jim
10-07-2001 15:00:13
My neighbor's 55 combine has a broken unloading auger. I haven't seen it yet, but I'm told the pulley and shaft turn, but the auger does not. I'm guessing it's a broken pin, or something like that. I'm going over to help him Monday, and wondered if anyone has has this problem and could offer a suggestion. A picture breakdown of the parts would be a huge help also. Thanks all for the help. Jim
Handsome Jim
10-07-2001 19:42:33
 Re: 55 combine... unloader auger doesn't turn in reply to Jim, 10-07-2001 15:00:13
Jim, Once you stand back and look at the mechanism that controls the 55's unloading auger you'll see that it's pretty basic and that you won't find any technological mysterys there.
The linkage from the control lever will lead you to a sheild on the right hand side of the machine at the top of the grain tank. You should have power up there. Make sure that the tightener pulley is lining up with the drive belt. If everything there is as it should be, You'll probably find that you got shear pin broke somewhere. In any case it shouldn't be a big deal, everthing should be fairly accessible. We had several 55's when dad was farming, but I haven't been on one for over twenty years but I do remember that as being a re-occuring problem and I was always able to take care of that myself with my limited mechanical savvy. Let me know how it turns out. HJ
jim
10-10-2001 20:49:49
 Re: Re: 55 combine... unloader auger doesn't turn in reply to Handsome Jim, 10-07-2001 19:42:33
Thanks, Jim for all the info! Turns out it is a modle 45! All went well and it's getting beans right now. Thanks again.
