Help, '78 JD 316 Kohler won't start
one click only
Joe Snapp
10-07-2001 19:48:36
I used it hard all day, then it would not start, starter won't turn. Battery is good, lights are bright, full of gas, in neutral, brake on, etc. Just a single "click" under the floor after the key is turned. Sound is NOT coming from the engine or starter, I can't see where it is coming from. I have not taken the cowling off yet.
Any ideas on what to check first? Buy a new starter and install myself? How much do you think?
Thanks in advance!
Joe Snapp
Bainbridge Island, WA
Lazy Horse
10-08-2001 05:54:14
 Re: Help, '78 JD 316 Kohler won't start - one click only in reply to Joe Snapp, 10-07-2001 19:48:36
Check all your connections and make sure they are bright and tight. If everything checks good you can jump a wire directly to the starter to test it, if it turns over its in the solenoid switch, if not it could be weak battery, bad switch, or a safety switch somewhere. you'll just have to check eertything out to find the problem.
