Jd B runs weird
Joey
10-13-2001 18:41:18
when my 46 john deere B idles or at full throttle it goes pop pop----- -pop pop----- --pop pop----- pop pop----- --and so on. at idle there is a 2-3 second stall between pops. i have rebuilt the carb. and put new plugs and wires in it. the throttle is constatly moving back and forth. could the governer have a broken spline? cause when i hold the throttle shaft, it runs fine. please help!!!!!
joe
10-16-2001 17:41:14
 Re: jd B runs weird in reply to Joey, 10-13-2001 18:41:18
can anyone tell me where to get a carborator for a
46 B? the number is scratched off. what kind of
carb u can find to fit a B, i will take. i must be
able to buy it on the internet. thanks.
joe
10-16-2001 17:39:36
gary
10-14-2001 18:46:17
Joey,
A lot of people have had problems even after having their carbs rebuilt by professionals (?). Do a search of this site and "Rummy's John Deere Bulletin Board" and you will find diagrams showing exactly what passages need to be cleaned, and how to clean them. It isn't too complex, once you know what needs to be done. (That's not to say that the governor is not the problem, but maybe this is a simpler solution.)
Good luck, whatever the problem turns out to be, let us know how you found and resolved it.
Kemper
10-14-2001 15:10:17
Pull your choke out slowly when it is running,if it smoothes out some you probably have a piece of dirt in carb,sounds like it is starving for fuel.
Will P
10-13-2001 22:38:23
Does the throttle open and close, open and close, when running at idle? If so, you are starving for fuel at idle. Clean out the idle passage. If not, please give more detail on what is wrong.
Will P
