1952 B wont stay running
Alan
10-21-2001 16:24:14
I pulled a grain drill all day sat.with little problems and cleaned the tractor up to use to pull the hay trailer with that night for a hay ride went about a mile and it started missing and would run with the choke out but got to the point I couldnt keep her running felt the pipe on the block side of the carb and it was freezing cold? on a gasoline engine im stumped any ideas would be appreicated thanks in advance.
Clooney
10-21-2001 17:20:48
 Re: 1952 B wont stay running in reply to Alan, 10-21-2001 16:24:14
Alan, did it re-start after sitting for a while? Does it run now or still won't run? Were you just idling along when it quit?
Alan
10-21-2001 19:04:29
 Re: Re: 1952 B wont stay running in reply to Clooney, 10-21-2001 17:20:48
It would start but couldnt keep it running pulled the card off today and have it soaking in chem tool but I couldnt understand why the pipe going into the block was getting cold when the tractor was running at 140 degrees.
Chuck
10-21-2001 20:36:56
 Re: Re: Re: 1952 B wont stay running in reply to Alan, 10-21-2001 19:04:29
frosting effect on the carburator is caused by high pressure effect of the air moving through the carburator, much similar to releasing an spray can. The air speed is increased by the smaller size of the throat in the carb and in turn will suck the fuel from the bowl. You need to completely clean the carburator, clean out all the passages, pull the main jet, etc.
Chuck
10-21-2001 16:40:12
you have two possibilities. Trash, settlement is stopping up your fuel flow or the low side of the carburator is stopping up. I'd go with cleaning the settlement bulb and carb filter. Other than that do a carb tear down and rebuild.
