Powertrol doesn't Trol JD B
Jerry C
10-25-2001 11:23:19
Two questions 1. What oil to use in 1949 JD B powertrol /
2. Where do I get some exploded view,etc for powertrol
1st Tractor, when I bought it, last week, Guy said it had been overhauled. Shift lever extension was gone (1st clue ??)so I didn't operate it.
Tried operating with pto engaged and dis-engaged..
nothing happens...so ???? thanks Jerry OKla
Jerry C
10-27-2001 07:29:40
 Re: Powertrol doesn't Trol JD B in reply to Jerry C, 10-25-2001 11:23:19
Thanks to all you guys the information was all a big help, now all I gotta due is get a manual and get after it Jerry
Clooney
10-25-2001 13:32:38
Jerry, can you hear the pump labor & the engine work a little harder when you try to raise it? If so the rock shaft is probably already in the up position & you will need to put the lever in the down position & put a BIG wrench on the square of the rock shaft & rotate the shaft to the down position before it will go up when the lever is moved to up. There is no power down.
Jerry S
10-25-2001 11:59:06
The oil many suggest using is 30 weight. I have also heard some use 20 weight. As far as drawings, there is some information in todd's tractor pages website and it would be good to grab onto a shop manual for the tractor. There is a separate one for just the power-trol that the deere dealers can get. The drain for the lift is a pipe plug straight below the PTO shaft. You might see what is in the bottom if it has water in it etc. Also, you have to have the pto running to make the pump work. I think it is a good idea to try to move the shaft a little to see if it is frozen or not. I wonder if it is just low on oil. Good luck.
Jerry C
10-27-2001 07:26:59
 Re: Re: Powertrol doesn't Trol JD B in reply to Jerry S, 10-25-2001 11:59:06
Thanks Jerry the information really helped out. Todds site has some excellent info and what manuals I most needed.Todds tractor pages are now located @ www.jd40.com Jerry
Russ
10-25-2001 12:11:10
The piston could be frozen, also for Rock-shaft operation the setting on the metering screw is 2 turns out. The plugs should have 2 holes, one in the end and one horizontal. Russ
