1949 John Deere B
Kenny Bruhl
10-28-2001 20:26:08
My B runs for about 30 minutes at idle before it starts to fuel foul the spark plugs. It runs about an hour, when under a load before it does the same thing. It has mag ignition which has been completely rebuilt. Carb is adjusted as lean as can be and still run properly, and I am using the hottest plug I can find. Any suggestions as to why the plugs continue to foul?
Will P
10-28-2001 20:52:23
 Re: 1949 John Deere B in reply to Kenny Bruhl, 10-28-2001 20:26:08
What are you using for a plug? Try Autolite 386. I had a little of the same problem. I had the mag just a little retarded so it wouldn't kick when I hand started it. But I adjusted it to be straight up. I advanced it basicaly. Now it hasn't given me that much problems. Don't know if this is the cure all. I bet others will help you too. Just see where your timing is.
Will P.
