Governor Gaskets
Jerry S
10-30-2001 06:36:40
I hear the gasket that connects the governor to the main case is not available anymore. Low and behold, I need to get a replacement for this 49A and need advice on the best way to go. I assume I need to make it out of a paper material but don't know what thickness to use. Not sure if that thickness is critical or not. Thanks for your help.
BobTGS
10-31-2001 09:03:11
 Re: Governor Gaskets in reply to Jerry S, 10-30-2001 06:36:40
Jerry, I have the correct gasket in stock for your A.IF you still need one ,give me a call at 1-716-542-3175,9am-8pmE.S.T. Bob,from Triple G Service.
gary
10-30-2001 18:02:29
Might cost you a few bucks but i think the gasket is available in the complete gasket set.
Will P
10-30-2001 19:50:27
 Re: Re: Governor Gaskets in reply to gary, 10-30-2001 18:02:29
The governor gasket is not available anywhere or how that I know for the A. It is available for the B, But the crankcase gasket isn't. But for the A the crankcase is. Now if they could only come together and make a COMPLETE set.
Will P.
Bob K
10-30-2001 10:08:35
On the governor for my 50, I went to the auto parts store and bought a roll of the tan-colored gasket material that was wide enough to cover the base of the housing. I don't remember the exact thickness but it was close to the thickness of the original gasket -- somewhere between 20 and 30 thousandths. Just make sure there is a little positive clearance between the cam and governor gear teeth. Also be sure to cut a hole for the oil passage into the governor from the crankcase. Good luck.
