2010 generator to alternator conversion
Gordon
11-14-2001 13:21:05
Can anyone tell me how to go about converting my 64 model 2010(gas) over to an alternator charging system?
John M
11-15-2001 21:04:52
 Re: 2010 generator to alternator conversion in reply to Gordon, 11-14-2001 13:21:05
After you install alt & change system polarity, you`ll have to replace fuel guage, for some reason neg ground blows orig guage.
Dixie Johnny
11-15-2001 08:03:03
If your 2010 has a positive ground 12volt system you will need to do the following: install a single post 12 volt alternator and run a 10 ga wire from the single post on alternator to the hot post on your starter, then change the polarity of the electrical system by swapping the battery posts/cables (+to- and -to+), disconnect/remove the voltage regulator and any other wires going to the present generator system. This has worked well on my 3010 that I converted several years ago.
G Taylor
11-15-2001 19:41:05
 Re: Re: 2010 generator to alternator conversion in reply to Dixie Johnny, 11-15-2001 08:03:03
The coil will have to sweapped to neg terminal to the points. The ammeter connections will have to be swapped as well.
Tom in Mo.
11-14-2001 19:57:53
You can't install an off the shelf alternator on a positive ground 2010 without additional changes. Why change? A completely rewired and rebuilt generator costs the same as an alternator without the extra trouble of changing other parts.
joe
11-14-2001 18:05:41
if it is a 12 volt, all you have to do is buy the
altinator.
