JD B CLUTCH
Joey
11-14-2001 18:03:57
i have a 46 B. when i am driving it and i
disengage the clutch, it makes a rattle noise. it
is like there is something in there. but it only
does it when i disingage it.
Clooney
11-14-2001 18:26:55
 Re: JD B CLUTCH in reply to Joey, 11-14-2001 18:03:57
Joey, the usual cause of clutch rattle when dis-engaged are the adjusting bolts hitting the clutch cover or worn driving disk to sliding disk splines, but there could be other causes including a dry or loose outer pulley bearing or inner bushing, worn dog pins, worn operating sleeve, loose driver,or excess crankshaft end play to name a few.
