Help! Horrific hydraulic leak in JD 2010
Joe Stewart
11-19-2001 17:05:17
Hello current and former 2010 owners! I purchased a 1961 JD 2010 diesel wide front row crop with power steering, dual rockshaft system and single remote hydraulic valve. Tractor ran fine but the power steering, 3-point and remote cylinder never worked. I tried soaking the filter screen in carburetor fluid and replacing the fluid. I did this twice and that didn't work. I finally bought a brand new wire mesh filter from john deere and (surprise!), the power steering, 3-point and remote cylinder work great! Problem: now hydraulic fluid pours out of the steering column near the hand throttle and soaks my pant legs and boots. This is not a "drip, drip" type of leak. It is literally pouring out and would probably drain the reservoir (8 gal) in about an hour. So I disengaged the hydraulic pump and now I'm back to having a tractor that runs fine with no hydraulics. I replaced the seal that goes right above the hydraulic steering valve, but that didn't help. The service manual doesn't address this situation. Any ideas from the 2010 experts out there would be greatly appreciated. Thank you! Joe Stewart
jd50
12-10-2002 22:38:28
 Re: Help! Horrific hydraulic leak in JD 2010 in reply to Joe Stewart, 11-19-2001 17:05:17
OWNER OF A 1963 2010 JD
HYDRAULIc leak @or above the pump
emptys out in about a half hour
when running it pours out ps working ok
no hydraulic @ the 3po any idais?
can i fix without splitting the tractor?
Red Man
11-19-2001 19:16:49
Your steering valve needs to be rebuilt. There is some stuff in there that needs to be set up with a dial indicator.
