Generator polarization
JeffS
11-21-2001 06:40:31
A LOCAL FARMER TOLD ME TO DO THIS WITH THE MOTOR RUNNING, IS THIS TRUE AND IS WHAT IS STATED BELOW APPLICABLE TO A 12V NEG GRND SYSTEM?
To properly polarize that generator, make sure the battery is charged in the correct polarity, then ground the F (fld) post on the generator & momentarily connect battery voltage to the ARM post of the generator
Clooney
11-21-2001 10:27:36
 Re: Generator polarization in reply to JeffS, 11-21-2001 06:40:31
JeffS, the way you explained it is absolutely correct because that works even if you have a bad or missing regulator, the only thing you should do different is NOT have the engine running during the process.
Thurlow
11-21-2001 08:04:36
BEFORE YOU CRANK THE TRACTOR, polarize the generator by momentarily connecting jumper wire between gen and bat posts on REGULATOR.
