John Deere B Clutch
Jerry Bantz
11-22-2001 18:40:56
I just put in a new clutch in my 36 b. and realized that when taking it apart the bolts that hold the retainer on are stripped. How would I remove these and replace with all new ones. I looked at my I&t and still am unsure. Any help would be appreciated. thanks Jerry
Clooney
11-25-2001 09:59:04
 Re: John Deere B Clutch in reply to Jerry Bantz, 11-22-2001 18:40:56
Jerry, what retainer are you refering to? The clutch bearing retainer is pressed in.
Jerry Bantz
11-25-2001 10:39:00
 Re: Re: John Deere B Clutch in reply to Clooney, 11-25-2001 09:59:04
What i meant was the three bolts in the clutch housing that hold the outside cluch retainer are stripped and I am wondering how I can take all three of them out and replace with new bolts.
Clooney
11-25-2001 11:51:15
 Re: Re: Re: John Deere B Clutch in reply to Jerry Bantz, 11-25-2001 10:39:00
Jerry, are you talking about the 3 movable adjusting bolts that hold the adjusting disk on? If so the whole clutch pulley has to come off which entails removing the pulley brake & clutch fork bearing & clutch fork shaft from the front of the 1st reduction housing then pulling the brake & fork out the front then removing the drive disk from the crankshaft then pulling the pulley off. Make sure to mark the drive disk to crankshaft before pulling the disk.
Jerry Bantz
11-25-2001 22:30:06
 Re: Re: Re: Re: John Deere B Clutch in reply to Clooney, 11-25-2001 11:51:15
Yes thats what I am talking about. Thanks for the advise Clooney, I appreciate it.
