1941 JD B has pipe with coil spring and shock type seat
Craig Noble
11-22-2001 20:49:53
My JD B has the shock and coil spring seat,was this original or an option? If so, I will keep it. But if not I will get the one with the flat channel.
Wendell,MN
11-24-2001 01:32:29
 Re: 1941 JD B has pipe with coil spring and shock type seat in reply to Craig Noble, 11-22-2001 20:49:53
hold on a minute! are you saying that it looks quite simular to the channel seat exept that it has a big tapered spring under the seat (instead of at the base of the channel) and has a shock behind the seat (behind the spring). If it is, then the seat is probably origional. My fathers was this way. My 39 B has the channel seat. I wish I had the pipe type though, I think it looks better.
Ben So Tex
11-23-2001 19:00:15
I have a 43 B and it too has the seat like your.
Don
11-23-2001 06:54:55
My father bought a 1941 B JD new. He changed the original seat to a Monroe Easy Rider. It was as you have described the seat on your tractor. It was a great improvement over the original JD seat.
Much more comfortable!
gene b
11-23-2001 06:22:59
not original but if the shock is good dont junk it as new ones can run as high as 50bucks
Russ
11-23-2001 05:42:29
I believe those seat were called an Easy Ride,and was added by the owner. Some had Pan seats, and the one on my 38 A had a square seat for a cushion. They are not John Deere, but its your tractor,and if rode on all day probably ride better than the original. Russ
Stan - Florida
11-23-2001 03:35:56
Optional seat - might be the Knoedler brand.
Stan
Stan - Again
11-23-2001 03:34:38
Forgot to ask - what's your serial number. My '41 B is 100220.
Stan
Mark-Florida
11-23-2001 05:28:04
 Re: Re: 1941 JD B has pipe with coil spring and shock type seat in reply to Stan - Again, 11-23-2001 03:34:38
Stan what part of Fl. are you from. I'm from pinellas park but have property in live oak by the way my 41 B is ser. # 109852 elec.start with a hoxey hitch , and with one of them fancy shock seats .
Stan - Florida
11-23-2001 13:38:38
 Re: Re: Re: 1941 JD B has pipe with coil spring and shock type seat in reply to Mark-Florida, 11-23-2001 05:28:04
Mark,
I'm from Melbourne. Sounds like you have one of those fancy models! LOL!! Electric start is something that will be on my next tractor, fer dang sure!!
Stan
