JD B starter sounds
joe
11-23-2001 19:57:58
my 46 B is electric start and has an open flywheel. when i go to start it is has a steady noise to it. i have a friend and heard many others that have an uneven starter noise, like na neer, na neer, na neer, and so on. both our tractors are 12 volt. not that it is hurting any thing, but i love the way those others start.
thanks
Brandon
11-23-2001 22:02:51
 Re: JD B starter sounds in reply to joe, 11-23-2001 19:57:58
The uneven noise is caused by the compression strokes of the pistons-it slows the starter down like on our 6-volt B (even with the petcocks open), and causes it to get louder.
With your 12 volt the starter probably has so much extra push that the compression hardly makes a difference.
Push on the lever...
Grrr,Grrr,Grrrrr r,Grrrrr rrr,Grrrrr rrrrr r
Will it hold together?
POPPP! POP! POP!
Yep!
Brandon
