HELP!! 40C is stuck in reverse
Jim
11-25-2001 11:27:37
I have a JD 40 crawler. While I was using it, it became stuck in reverse. What do I need to do to free it up? Is there a simple solution? Thanks Jim.
Mark
11-25-2001 14:08:29
 Re: HELP!! 40C is stuck in reverse in reply to Jim, 11-25-2001 11:27:37
If its the main trans just pull the shifter off and line up the gates on the rails, and reassemble the shifter. Probably have worn rails and or shifter just be carefull shifting so you don't pull the shifter past the gate.
