Diesel injection line broke: Is a patch available?
Joe Stewart
11-30-2003 06:14:34
Hello John Deere experts and diesel enthusiasts in general! I have a 1961 JD 2010 diesel row crop. Fuel began spurting out of the #3 injector line at the fitting that holds it to the injector. I loosened the fitting and discovered a crack in the solid steel injector line, just above the compression sleeve. My question is: Is there a temporary injection line available that I can use until the local JD dealer can get me a replacement steel line? Thanks! Joe Stewart
upperpinecreek
12-02-2003 09:58:34
 Re: Diesel injection line broke: Is a patch availa in reply to Joe Stewart, 11-30-2003 06:14:34
just a point of info to help you or others with same problem for injection lines, i own a hyds co and one of the pieces we have in our shop is a patented machine for making steel lines of all types, if someone in your area has, is called "tubes @ hoses" they can make you an exact copy if have your old one. we make them regular for customers when not available from dealer.
Joe Stewart
12-01-2003 10:04:47
Thank you for all the replies. The local JD dealer first tried to sell me a #2 (his mistake) injection line for $121.00. I caught the error, and he looks up the price for the #3 injection line: the #3 injection line is "obsolete" and he can't get it. So it looks like I'll have to braze this one and hope for the best, not unless one of you has one to sell me. This is for an early model 2010, before serial #29000. Thank you all! Joe Stewart
F-I-T
12-01-2003 10:11:15
 Re: Re: Diesel injection line broke: Is a patch av in reply to Joe Stewart, 12-01-2003 10:04:47
Joe:
You might take your old one to a local diesel rebuilding shop that has a good reputation, and I bet they can make you a line or repair yours.
Frank
RAR/IA
11-30-2003 14:33:59
The dealer should be able to special order one in 24 hours if they are available. Costs a little more for the freight. Not worth all the possible hassle with other problems.
Roger
F-I-T
11-30-2003 07:22:13
Joe:
That steel line has to retain hydraulic pressures in the neighborhood of 2400 psi, and like Allan said, all the lines have to be the same length for best operation.
That said, if one is careful, it can be brazed or even silver soldered for temporary usage. It may or may not ne successful. Nothing but steel will hold the pressure. Be sure you have your lines clamped down properly so that they do not vibrate. That's what causes most line cracking.
Frank
farmebill
11-30-2003 17:40:10
 Re: Re: Diesel injection line broke: Is a patch av in reply to F-I-T, 11-30-2003 07:22:13
I thought that those injectors opened at pressures ALOT higher than that. Maybe I am thinking of something else. Is 2400 right for sure? Just wondering.
F-I-T
11-30-2003 18:19:41
 Re: Re: Re: Diesel injection line broke: Is a patc in reply to farmebill, 11-30-2003 17:40:10
FB:
The only book I have nearby is for my 70D, and the breaking pressure on it is 2400 psi. I think that's pretty much in the neighborhood for breaking pressure. Some no doubt are lower, and I'm not familiar with any that are higher, but that doesn't mean there are not.
Frank
Dieselrider
11-30-2003 15:00:56
If it were mine I'd weld with atcetylene then clean out real good loke Clooney said.
Clooney
11-30-2003 08:01:34
Joe, if you weld, braze, or heat that line be sure to clean ALL the scale out of the line & even use a small wire brush.. In heating that line, the inside will form a scale & if that gets into your injector you won't be a happy person...
JDClooney@aol.com
F-I-T
11-30-2003 08:34:17
 Re: Re: Re: Diesel injection line broke: Is a patc in reply to Clooney , 11-30-2003 08:01:34
Good point, Clooney!
And maybe follow the wire brush with some phosphoric acid to dissolve any vestiges of flux that might leak through the crack and remain. Then flush with lots of hot water, and maybe the pressure washer, then oil it with diesel fuel again.
Frank
Allan
11-30-2003 06:40:18
Hi Joe,
I doubt it. The length of that thing is somewhat critical for timing purposes. I'd just wait till the new line gets here.
Allan
