JD MODEL 70 3 PT HITCH CAPACITY
Jim
11-27-2001 10:00:58
CAN SOMEONE TELL ME WHAT THE LIFT CAPACITY(WEIGHT LIMIT IN POUNDS) IS FOR THE 3 PT HITCH (Power-Trol) at the point of the lift pins for a 1954 JD Model 70 gas. Want to make sure I don't overload the ole gal. Would appreciate any information you can provide.
Clooney
11-27-2001 10:12:28
 Re: JD MODEL 70 3 PT HITCH CAPACITY in reply to Jim, 11-27-2001 10:00:58
Jim, can't give you the lift capacity as that depends on the length of the arms on your 3-point. Mine will lift 1000#+ at the tool bar on my home-made 3-point. I wouldn't worry about hurting anything as there is a pressure relief built into the power-trol to protect it.
poorerbut
11-27-2001 11:58:58
 Re: Re: JD MODEL 70 3 PT HITCH CAPACITY in reply to Clooney, 11-27-2001 10:12:28
I can't give you pounds or torque either, but I've had a 4-16 full mtd plow on an after-market 3pt hitch (I think she's rated @ 4-14 plow) where the front end is really goosey and never worried about pulling the powrtrol off the rear end.She's a pretty gutsy lady and they did make front end weights for her. Like Clooney said, the relief valve is designed to protect her. pb
