Where can I find pushrod tubes for a '38 JD B head
John Dear
12-02-2001 17:04:25
I need pushrod tubes for an unstyled JD B as I seem to have one leaking. JD says they are no longer available through them. Does anyone know where I can find a set? Anyone ever made their own?
Thanks
Jonathan
Bob
12-02-2001 21:52:32
 Re: Where can I find pushrod tubes for a '38 JD B head in reply to John Dear, 12-02-2001 17:04:25
Your JD dealer isn`t trying very hard to help you. I bought two sets in the last six months from JD. Try part # B1290R, they cost about $9.53 per tube.
john dear
12-04-2001 16:05:57
 Re: Re: Where can I find pushrod tubes for a '38 JD B head in reply to Bob, 12-02-2001 21:52:32
Thanks for the info. I called Deere. Part number is good, they will have 4 for me in the morning.
Thanks
Jonathan
Hil
12-02-2001 20:49:54
Make your own tubes. I made a set for a 1945 B. Take the tubes out and get the measurements off one of the old ones. Cut you a peice of 1/2 stainless steel pipe the correct length. The ID will be close enough, then put it in a lathe between centers and turn it to the correct dia. The front end will be a couple of thousands larger and also thin the middle of the tube dowm a couple of thousands. Drive the tube in from the front, valve cover side.
