1010 Ignition questions
Jerry
12-02-2001 20:55:06
Real novice with gas JD 1010 wheel tractor needs advice. Has Waco Magnito system.
1) Firing order, 2) Is front plug #1 or #4
3) Where on distributor does #1 plug wire go?
Any help will be much appreciated. Thanks
Larry W.
12-03-2001 06:19:22
 Re: 1010 Ignition questions in reply to Jerry, 12-02-2001 20:55:06
The firing order should be 1,3,4,2. Front of engine is number 1 cylinder. If the distributor or cap is not marked, you can probably start with number one anywhere you want, then work around in the direction of rotation with the other plugs in firing order. I have never had a JD with more than two cylinders, so am not sure. the other tractors I have worked on except 9n Fords had no particular preference where the plug wires started out as long as they wnet on in firing order. As far as firing order, I assumed it to be the same as all the other fours I have worked on. Hope this helps.
