1010 diesel in sump
phill
12-05-2001 02:56:42
My 1010 oil level keep slowly rising (and there's no pipes going down into the ground.) Does anyone know how fuel is building up in the sump and more importantly how do i fix it
thanks, phill
Raye
12-05-2001 16:18:22
 Re: 1010 diesel in sump in reply to phill, 12-05-2001 02:56:42
The injection pump has two umbrella seals that
that keep diesel from getting into the crankcase.
Over time they get hard and leak.You probably
have a Roosemaster pump.The seals can be replaced
after pump is removed and bottom shaft pulled out,
pump does not have to come apart.The tricky part
might be getting the seals.Most pump places want
you to rebuild the pump.
Thurlow
12-05-2001 03:57:32
Probably, diaphragm has failed in your fuel pump.
Thurlow
12-05-2001 03:57:04
