John deere D
joe
12-05-2001 19:02:55
i have a 45 D and it hasnt been running for 10-20 years. i put new plugs, wires mag, and fuel in it.
i pulled it with my A and it fired up! my question is why does it backfire nonstop?! i tried to time it all the way to the front and all the way back (the mag) it didnt help. should i rebuild the carb? please help
joe
Leger
12-05-2001 19:29:18
 Re: john deere D in reply to joe, 12-05-2001 19:02:55
Try un crossing the spark plug wires.
Clooney
12-05-2001 19:17:15
Joe, sounds like you are either fighting a carb problem or you have a leaking or sticking valve or valves. Does the load & idle needle have any effect on engine running (not the backfiring) if the needles have control of the fuel mixture then you probably have other problems like valves or? If there is little or no control with the needles then you might have carb problems. Try running with the choke on a little or 1/2 on & see if that helps. Run it for a while then run a compression test on it (hot with the carb wide open) You might want to try running it without the air cleaner attached in case something built a nest in the air cleaner or stack. You will need to do a little more testing & eliminating for us to pin a backfire down over the internet.
kh
12-05-2001 19:12:28
Maybe a valve is sticking open.
jimbob
12-11-2001 17:11:48
 Re: Re: john deere D in reply to kh, 12-05-2001 19:12:28
For what it's worth, when i got my 1931 D it backfired something fierce. Winded up being out of time almost 90 degrees! It is a wonder it even ran.Recheck your timing would be a good place to start. Remember, old Deere's are not complicated to diagnose. Good
