2010 trans.
Tom Trolley
12-08-2001 09:07:34
I recently acquired a 2010 RU with an existing trans. problem. It will shift between gears in one range only, but won't change ranges. I removed the trans. cover, but can't seem to move the range changer. Nothing appears broken or worn. I have a service manual, but it just tells how to remove the trans. and not how to troubleshoot the problem. Is there anyone out there with some expertise or should I just plan on pullng the trans. apart. Thanks!
ben brown
12-09-2001 07:56:34
 Re: 2010 trans. in reply to Tom Trolley, 12-08-2001 09:07:34
tom first thing i would do is undo the linkage from the shifter to the trans. and make sure the problem is not in the shifter drum thies have been known to freeze up on shaft and give problems then check and see if you can move range shifter in trans. if not remove detent on side of trans. you manual will show you where it is located the spring could be broken locking trans. shifter
