1935 D Air intake removal
Marty Z
12-13-2001 07:36:54
Hi,The stack on the air intake is straight now, but the can at the top has several large dents in it that I would like to fix. Is there a way to get the can off the stack so I can tap them out from the inside? As it is right now I would have to layer in about 3/4 " of filler. I tried some heat at the bottom end of the can and got some solder to puddle. Should I keep trying,or should I work at the lip around the bottom perimiter?
Thanks
MJZ
