Jd B carboretor problem
joe
12-14-2001 15:14:04
i have a 46 b with a dltx34 carb. i got the idle addjusted properly, but i cant get the high speed adjusted right. it runs uneaven and doesnt have any power at 1/2 to full throttle. right now the high speed is out 3/4 turn. what is the average setting? please help!!!
joe
gary
12-15-2001 06:15:25
 Re: jd B carboretor problem in reply to joe, 12-14-2001 15:14:04
Joe,
I would try opening the load needle a full turn (another 1/4 turn from where you have it.) Have you had the carburetor apart for cleaning? Sometimes there are passages that are easy to overlook that need cleaning (reaming) out.
(My manual says the adjustments should be made when the tractor is warm and at 3/4 throttle.)
Larry W.
12-15-2001 06:09:44
Start with it out about 1 1/2 turns. Then what I do, is after the tractor has warmed up a little, open the throttle wide, watch the exhaust as you turn the screw out a little tiny bit at a time. If it smokes black, you are getting too rich, and then back off a little bit. If all else is well, it should be ready to pull something. If you have something to pull, it may still need a little more gas.
