2010 Stuck Engine
Blake
12-16-2001 10:11:13
Would a 2010 engine, clutch, and transmission- about 45 horsepower, with a stuck engine be strong enough to undergo dragging and popping the clutch without tearing up something severely. Thanks
G Taylor
12-17-2001 20:06:19
 Re: 2010 Stuck Engine in reply to Blake, 12-16-2001 10:11:13
It was parked because something was wrong with it after nearly 40 years of age/usage. Yanking it now after adding three years of corrosion will make you say " them old Deere's are no good". A gasket set is a cheap price to tear it down & have a look. A 2010 is best used as only a parade tractor & part of a 1010 through 5010 collection. Good intentions but they had numerous problems. They rate right up there with Manhiem 510's & 710's.
Tom in Mo.
12-16-2001 16:41:20
Squirt your favorite lube into the cylinders many times for many days; I use Kroil. Let soak. Rock the tractor while in gear useing the rear tires to rock back and forth. You can get a lot of leverage pushing and pulling on top of the treads. Patience is the word.
I have freed two tractors like this. If it won't let go like this, the cylinders are probably pitted and should be rebuilt.
rex
12-16-2001 13:20:57
i have some ??? before u can get a serious answer. is it a gas or diesel 2 do u know how long its been stuck ? has it been outside in the weather ?answer back and i will give my best guess.
blake
12-16-2001 18:50:09
 Re: Re: 2010 Stuck Engine in reply to rex, 12-16-2001 13:20:57
It is gas, and it has been sitting about three years, but i'm not sure wether it was used w/out oil or if it just froze over time. It has been sitting out in the weather also
440Sam
12-16-2001 11:19:42
If 2010 engine is stuck and due to its design a teardown is required. If you free the engine by pulling be assured that a rebuild will be necessary.
blake
12-16-2001 18:56:02
 Re: Re: 2010 Stuck Engine in reply to 440Sam, 12-16-2001 11:19:42
So you are saying that if I free the engine by pulling it in gear then I will have to rebuild or overhaul the engine.
440Sam
12-17-2001 18:13:21
 Re: Re: Re: 2010 Stuck Engine in reply to blake, 12-16-2001 18:56:02
Blake, I purchased a 1010 (same engine design) with a stuck engine a few years ago tried the pull and pop clutch routine and ended up having to tear the engine down. Question - Is there antifreeze/ water in the oil? If so the copper gaskets at the base of the cylinders have failed. making a rebuild necessary. It is very doubtful you can free a 2010 engine and it function correctly. May I suggest that you look for a running 45 combine engine (early round back with a JD 145 Power Unit) and replace your 2010 engine. It is the same and will bolt in with the changing of the valve cover, oil pan, etc.
Don
12-18-2001 20:04:57
 Re: Re: Re: Re: 2010 Stuck Engine in reply to 440Sam, 12-17-2001 18:13:21
I know of 2 jd45 roundbacks, shedded, haven't been ran in a couple of years but ran good when they were parked. Located in southern Indiana. Make an offer.
Ouch...
12-16-2001 10:59:13
that way to kill a old stuck tractor... huh..
The Stranger
12-16-2001 10:20:01
In a word, no. If it's stuck that bad, "dragging and poppping the clutch" is only going to bend/break parts. Either do it right by taking the engine apart, or don't do it at all!!
