John Deere D wheels
John Jenkins
12-16-2001 13:44:40
What style wheels were put on the unstyled Ds?
I have a 35' D on rubber with cast rears and spoked fronts. Is this original? What wheels were used?
Thanks
Clooney
12-16-2001 15:15:04
 Re: John Deere D wheels in reply to John Jenkins, 12-16-2001 13:44:40
John, the info I have on the 35 D's is a little iffy but most likely your tractor came on either the JD-1200R 20 spoke rear steel wheels, the JD-1200R round spoke with 12.75 or 13.5 rubber, or if after s/n 123200 the AD-1472R cast with AD1322R rim for 12.75 or 13.5 rubber. There was a late change for a short s/n range 123100-123200 that used the 12 spline axles (go figure) & the AD1343R cast wheel. Cast rears with 18" spoke fronts were common on the later un-styled "D's" & in my estimation looked real good that way, but I am kind of partial to the un-styled "D's". If your s/n is between 123100 &123200 let me know & I will do look up the spoke options for the 12 spline axles.
