1020LP
James
12-18-2001 17:59:04
I found a JD 1020LP tractor. Did JD ever make such a tractor? Is it worth $3500?
BIG JOHN
12-19-2001 04:10:23
 Re: 1020LP in reply to James, 12-18-2001 17:59:04
Yes< deere did make a few 10 series propane, check parts for part numbers, if starts like R12345 most likley deere- if so worth 3500.
Tom in Mo.
12-18-2001 18:21:55
It's probably a conversion. Deere did make 3020 and 4020 LPG models.
The 1020 gasoline model is a fine tractor, so if it was done properly, the LP conversion should be o.k. although with the lower compression the H.P. would suffer.
