1956 JD 60 Wiring
Brian
12-20-2001 07:39:09
I bought a 60 that has an alternator and negative ground but half of the wires are gone. If anyone could provide me with a wiring diagram for this setup I would appreciate it. I can not afford to buy the manual quite yet. Thanks
Clooney
12-20-2001 07:46:30
 Re: 1956 JD 60 Wiring in reply to Brian, 12-20-2001 07:39:09
Brian, there is no factory wire diagram for a 60 with an alternator, they came with generators & positive ground. What type of 60 & s/n do you have? What wires are gone? What brand & type of alternator is on it & how many wires are going to the alternator?
Brian
12-20-2001 08:11:42
 Re: Re: 1956 JD 60 Wiring in reply to Clooney, 12-20-2001 07:46:30
Clooney, I have a row crop model, s/n 6061432. I am aware that it did not come from the factory with an alternator and negative ground but I would like to see if I can make it work this way before I change anything. It has a delco 3 wire alternator. Specifcally I need to know where the wire coming from the starter switch connects. I assume it connects to the ammeter, and also where the 2 wires coming from the alternator connect.
Clooney
12-20-2001 11:36:10
 Re: Re: Re: 1956 JD 60 Wiring in reply to Brian, 12-20-2001 08:11:42
Brian, I re-sent them..I wonder who bk@hotmail.com is as he received some strange files?
Clooney
12-20-2001 10:19:50
Brian, I had to send the wire print by E-Mail, my picture server is down at this time.
Brian
12-20-2001 11:08:27
 Re: Re: Re: Re: 1956 JD 60 Wiring in reply to Clooney, 12-20-2001 10:19:50
Clooney, I did not get your e-mail. I mistakenly typed in the wrong e-mail address on my second post. It should be bk3020@hotmail.com. If you could resend it I would appreciate it, and thank you for your help here and on other questions. I have a lot of my questions answered by you just from reading other posts. Your expertise is invaluble. Thanks again and Merry Christmas!
Clooney
12-20-2001 11:37:20
 Re: Re: Re: Re: Re: 1956 JD 60 Wiring in reply to Brian, 12-20-2001 11:08:27
