1965 4020 diesel fuel overconsumption
Paul
12-29-2001 18:44:14
Hi everyone!
Just stumbled across this site and really have enjoyed it.
We have had a 4020 diesel since 1965 (we also have a 4020 gas since 1967 and a JD-M from way before my time. We still use all three.
My dad just had the diesel engine rebuilt at a dealer (mistake#1) $12000 later and a few trips back it still isn't what it was before he had the engine rebuilt. It has a power shift tranny, and could pull a 5row-14"bottom plow no problem in 5th (we live on brookston clay - known as concrete) and run about 8 hours on a full tank of fuel. So obviously the HP was up to about 105 or so. He even pulled an 8 bottom plow in 3rd gear.
Since the rebuild (new injectors, pump, etc.etc.) the tractor runs about 5 hours on one tank and the HP is now only 86!!!!!They can't squeeze more out at the dealer. (I told my dad to go to someone local who does excellent work! This guy has a 4020 running at 130HP no problem!)
What should the fuel consumption be back when it was original and would we have any way of getting the dealer to keep working on the tractor till it was horsepower wise before?
Thanks
Paul
twopop
12-30-2001 19:02:29
 Re: 1965 4020 diesel fuel overconsumption in reply to Paul, 12-29-2001 18:44:14
from what you are saying about the power falling off and not recovering ,I believe the camshaft timing should be rechecked.
Bob W
12-30-2001 16:51:46
Paul; Sorry you are having so much trouble with what should be a great tractor. I think you should be getting in touch with your TAM (territory aftermarket manager) he works for YOU and Deere. He should set the dealer right. Put up another post and I will get you his number if you wish. I work for a Deere dealer down the 401 a ways from you and feel that any reputable dealer (Ican guess who you are dealing with) should stand behind his work and not be billing you to get this machine right. All you other guys reading from stateside please remember the exchange on the US/Canuck buck is about 1.50: 1.00 ($12000 Canadian =$8000 US) Meanwhile Paul don't give up Bob
Paul
12-30-2001 19:53:18
 Re: Re: 1965 4020 diesel fuel overconsumption in reply to Bob W, 12-30-2001 16:51:46
I would very much appreciate that because its been eating away at my dad for a couple of years now. How do you feel about the situation in terms of horsepower and fuel consumption. Is it something that the dealer should get the tractor at 105 110 or more horsepower if he can or just stop at the bare minimum.
You might know who it is but we still do a fair bit of business there but being loyal is one thing being taken is another.
Thanks
you can reach me at my email:
pennsylvania@hotmail.com
Paul
Brokenwrench
12-30-2001 10:23:09
No offence intended but at $12000. for an overhaul, somebody got screwed with their pants up. I did a 72 4020 last year for a customer, Crank turned, all new valves, seats, guides new high ring liner kits from Clevite,pump rebuilt and 6 rebuilt injectors, dyno'ed at 125 hp. Total bill parts & labor $5744.25 and that included fixing some small odds and ends. If the dealer won't stand behind his work then I'd say get a lawyer, call Deere and complain. Your tractor with the pump set at stock specs. and new design liner kits, a good redone head, should dyno at 100-to 110 hp at an altitude under 2000 ft. One more question, did they overhaul the original engine or install a Deere re-man engine? I've run into a couple of them that were seriously down on power right out of the crate.
Don
12-30-2001 13:07:43
 Re: Re: 1965 4020 diesel fuel overconsumption in reply to Brokenwrench, 12-30-2001 10:23:09
I AGREE WITH BROKENWRENCH, YOUR DAD GOT SCREWED ROYAL. DOES THE TRACTOR HAVE PENCIL NOZZLES OR ARE THEY THE LARGER ONES ? TO BE 1965 THEY SHOULD BE THE PENCILS, HOWEVER , IF THEY ARE THE LARGER NOZZLES THE TIPS COULD BE OUT OF TIME . THIS MAKES FOR A LOT OF SMOKE AND NO POWER.I ONCE HAD A 3010 WITH THIS TYPE OF PROBLEM AND THE INJECTORS WERE OUT OF TIME AND THE PISTONS WERE IN BACKWARDS, IT WAS ONE SICK TRACTOR. I USED TO OVERHAUL 4020'S AND TAKE 3 DAYS TO DO IT (8HR DAYS). WE REBUILT OUR OWN PUMPS AND NOZZLES AND GROUND THE VALVES AND SEATS.THE SLEEVES AND PISTONS KIT FROM DEERE ARE SOMETHING LIKE $1200,PUMP AND NOZZLES RUN ABT $5-600 NOW IF THE DEALER CHARGES $60 AN HOUR AND IT TOOK 40 HOURS ?????THE FLAT RATE IS SOMETHING LIKE 13.5 FOR SLEEVES AND PISTONS.I RUN A 4020 P/S PULLING 5-16"BOTTOMS IN THE CLAY HILLS IN 4TH GEAR MOST OF THE TIME AND 8 - 10 IN DEEP . THE TRACTOR RUN 130 HP AND YOU BETTER BE AT THE FUEL BARREL IN 4.5 HOURS OR YOU WERE WALKING. STOCK HP ABT 94 YOU SHOULD RUN ABT. 5 GALLON PER HOUR DEPENDING ON HOW HARD YOU WERE PULLING. ARE THE RPMS UP TO SPECK?,ARE THEY THE SAME? KEEP US POSTED AS TO HOW THIS TURNS OUT AND IF THE HP COMES BACK. DON
Paul
12-30-2001 13:45:33
 Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Don, 12-30-2001 13:07:43
I just talked to my dad who is in his typical, I don't want to spend more money on the tractor mood. I don't blame him and he shouldn't have spent what he did to begin with but that is how it ended up.
The nozzles were very close to new but the motor needed a rebuild, so he brought it in. It had 105 HP appx before and I will ask him about the nozzle size now.
The first time the tractor came back to our place, from the shop it was dyno'd at about 80 HP or so. So my dad took it back to get them to look at it and they put in new injectors (nothing wrong with the old but they sent them back in exchange for the new ones so we will never know anyway. (My dad had asked them to give the old ones to him so he could put those in.
They managed to squeeze another 5 or 6 HP and the tractor came to our place. Then we sent the tractor back because we still were short about 20 HP from before we brought it in the first time and they must have screwed something up. (All the while, my dad is being billed for all the extras!) nice eh?
So now the third time, my dad had sent the tractor back (after about 30 hours) then they replaced the injector pump $1500 canadian) and a few other things of which the original one was sent for a rebuild the first time.
Now they claim to have dyno'd about 91 or so. Maybe a little better since we've put 400 to 500 hours on the motor. But still chews through the fuel and bogs easily with no recovery.
My dad knows that the distributor cannot be moved (very little) and if it is moved, the engine either spark knocks like crazy or doesn't start so we can't go that route on our own. Now since talking to my dad, he asked the easiest method to set the timing of the pump and whatever else we can try on our own. (Maybe the dealer put spark plugs in it, who knows? haha)
My dad is pretty complacent and has complained to the dealer but as long as they get the tractor close to spec horsepower wise then they are not obligated to do anymore work on the tractor. and its not they are doing it for free anyhow, my dad gets soaked everytime. Nothing short of tearing the motor apart we want to try the other things first.
Also (i have listed in the 4020 link on this site the model numbers of the two 4020's we own, if that helps)
It's been a rough few years for plowing but still, the tractor shouldn't bog down plowing 6" of corn ground with lots of moisture and a 4 bottom - 14" plow. It was boggin in 3rd so i had to plow in 2nd. We had the dual on the left side as per normal and there wasn't much slippage but the RPM's would drop from 2250 down to stall (if we let it go that far). As far as i remember, growing up, (i am 33 now), we always pulled in 4th or 5th gear plowing or whatever field work.
Now its drop 2 gears or put the tractor away. Even the gas 4020 (which needs a rebuild, burning way to much oil and gas) can do a comparable job.
Well I hate to waste any time of yours, I just want to do what i can for him because i know he is planning on getting a 17' or 18' high clearance triple-k with packers so we need something in the horsepower department. Right now we use a 3point hitch mount triple k (13'wide) with a land leveller (for the finishing pass) and a set of packers. It has a hard time in 5th (if you want to get into the soil deeper than a couple of inches).
Thanks for all your help,
Paul
Don
12-31-2001 12:43:22
 Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Paul, 12-30-2001 13:45:33
I'm guessing that they have set the injection pump to stock settings and they wont turn it up. You will have to get somebody to set it up for you. That will mean a tear down of the pump as they probably have shims behind the leaf spring. Wish I was closer to you as it takes abt. an hour and $30 for a kit. If you have somebody that knows pumps have them check "The speed advance timeing". This can kill HP if it's not right. Don
Paul
12-31-2001 14:15:11
 Re: Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Don, 12-31-2001 12:43:22
Will do!
I'll try that first.
Thanks
Paul
Paul
12-30-2001 11:23:03
I agree with you, its my dad's tractor from the start and I had told him to take it somewhere else. They even had a guy who's been doing it for 30 years working on the motor. It was the block pulled from the tractor not reman'ed.
That wasn't the worst, it's been back 3 times since the first shot at it because my dad complained but only a little better each time. Unfortunately, unless I take these emails in WITH my dad and confront them at the dealer, nothing will get done. Also, that is $12000 Canadian dollars but unnecessary as far as I am concerned. The dealer claims that they are only obligated to get the bare minimum for horsepower not what every one else has.
The injector pump is new and has been sent back twice for tweaking, the injectors, motor internals, etc are all new. You would think they could dyno more than 91 hp...at first all they could get was 84!!! We just need some ammunition to get somewhere further.
Thanks,
I appreciate the response and will be talking to my dad later this afternoon about it and maybe we can get a game plan before spring starts!
Paul
Handsome Jim
12-30-2001 06:21:56
4020 diesels were rated at 94 hp and that never varied to much with ours, however sometimes fuel did play a factor.. We never had any major work done on any them so I have nothing to offer there. When we plowed, we only pulled 4-16s with them because we had a lot of Missouri River Bottom Gumbo. I never kept track but I'm sure that Dad said we'd use between 4 - 5 gallons an hour. 12 grand sounds like a ton of money for a re-build job but I've been away from it for awhile.
Mike Aylward
12-30-2001 06:19:18
Paul, I agree with the others and suspect pump timing to be off. A well tuned 4020 should always put out over a hundred h.p. Normal fuel consumption should be between 4 and no more than 6 gallons per hour. I have two 4020's that I use as my main tractors and they both put out well more than this with no more fuel consumption. It could also be that the valves are a little tight, or possibly a restriction in the air supply or in the fuel return circuit. There are many possible reasons, but something is definitely wrong. Both of my 4020's run up around 130 h.p. and have done so for years. Hope this helps. Mike
What are you smoking?
12-31-2001 22:21:07
 Re: Re: 1965 4020 diesel fuel overconsumption in reply to Mike Aylward, 12-30-2001 06:19:18
130 horsepower naturally aspirated? I don't think so, your dyno must be in BAD need of calibration!!!
Paul
01-01-2002 08:11:17
 Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to What are you smoking?, 12-31-2001 22:21:07
I don't run the dynos!
We have a guy who has a 4020 stock, tuned to the 9's and throwing 130hp. He runs a 5 bottom 14 in 5th no problem, without breaking a sweat.
It has no turbo. No junk. I can't really say too much because he's a very knowledgeable man in his own right, and everyone has praise for his perfectionism.
I know, it is hard to believe. a 4320 puts out that and i believe a 5020 was 135 hp stock.
oh well.
i am not callin, anyone a liar, just what i've seen and heard. not sayin it would be good to crank it to 130 but if it works more power!
paul
Paul
01-01-2002 08:20:15
 Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Paul, 01-01-2002 08:11:17
Also I haven't had the experience like a lot of you guys do. My dad who has been farming for 60 years or better, says the transmission might not take it if we cranked it to 130 but I am an engineering technologist and the safety factor that manufacturer's put in is about 1.2 to 2 times what it rated to handle. I am cornfused but just to get up to 105 or so would be fantastic. People soup up engines for cars all the time, but they put non stock components in it to get it there (usually) unless they use nitrous.
People 'overclock' they're computer processors to run the processor at 700 mhz instead of the 566 mhz they bought it at and you just have to watch the heat.
Thanks
Paul
Paul
12-30-2001 11:30:24
Thanks for the info, as I am looking further into this, I think something stinks more and more...
My dad is an automobile mechanic by trade but can't do alot of the heavy work on the tractors like he used to and we don't have a reliable diesel pump rebuild guy around the area.
We live in southwestern ontario near windsor/ detroit michigan border. We just need some ammunition so we can get it fixed cause its killin my dad to spend the extra dollars for fuel and still not have the same tractor as before.
Thanks
Paul
John A
12-29-2001 20:10:32
We live at 4500 ft elevation and 86 hp is about all you could expect from a stock 4020. The big drop in power and increase in fuel hunger is a little weird. If it is hard to start, smokes at idle, just doesn't sound right, I'd lean towards pump timing. At any rate, sounds like your Deere dealer has some explaining to do.
As for pulling 5 bottom plows with 4020's, come to Colorado. I pull 5-18's with a 4840 (set at 195 hp) in 4th gear. Tell me all about your tough clay. I can GUARANTEE you won't pull a 5 bottom here with a 4020 in 4th or 5th gear. Probably not in 2nd. 4020's were considered good 3 plow tractors.
Paul
12-30-2001 11:50:00
 Re: Re: 1965 4020 diesel fuel overconsumption in reply to John A, 12-29-2001 20:10:32
We live near windsor ontario canada (50 miles from detroit michigan) and its basically sea level. Actually we used to have a 4640, 5020 and some oddballs inbetween and the 4020 seems to pull the best for plowing out of them all. We only plow 6 inches deep with 5-14"s sometimes 4-14"'s. We have pulled 8 rows in 3rd gear before when the tractor was newer but have since pulled 3 bottoms off. It is a cockshutt plow with hydraulic resets and pulled really nice (as long as the tips and shears are new and the coulters are lined up where they should be.
As for pulling 18" bottoms, that's alot to ask! I know of one guy that was pulling 7 16" bottoms with a 225 HP 4 wheel drive white and it was luggin in marshy ground!
They tend to beat the soil around here a little in the nicer ground, but when you've got tomatoes or green peppers it's too much to leave just becuase it's wet.
Plowing wheat is no problem but corn ground tends to be tougher to plow and not usually under ideal conditions. We have started to use a 9 row chisel plow set at 12" centres and left/right shovels (no coulters or disk in front) and it seems to do a good job as well. But still rely on the 4 or 5 bottom for corn.
I'd like to do some deep tillage but we don't have the horsepower to pulling some of these newer contraptions (subsoilers, offset disks w/deep tillage points, soil savers) you almost need a 7400 or 8400 jd for that!
Man you must have some tough ground with no organic material to make it that tough! Our ground is renowned as something to really farm! Silt sand clay loam soil with just under 1% organic matter, a lot of times we can't get the plow into the ground and stay there unless we get a few inches of rain beforehand!
Most guys in our area run 14" bottoms or in the tougher ground have better luck with running 12" bottoms (kongslide or triple k). I would switch from the 18"'s if its that hard to pull and get 6-14"'s.
Thanks
Paul
JDJIM
12-29-2001 19:12:22
$$12000 am I reading that right , what did they do for that much ? Does it have a turbo on it ? I've been playing around with 4020's for a long time I'd like to know more about this . 6+ gal/hr and 86hp don't sound good , does it smoke a lot ?When 4020's were the main horses here we pulled 5-14's in 4th most of the time 3rd about 25% of the time in Illinois black gumbo about the toughest thing . Had 100-05 hp used 5-6gph , non turbo . Do you know exactly what they did to this tractor like rebuilt pump injectors or new ? Timing could be off , how does it start , run smoke ect . JIM
Paul
12-30-2001 11:58:19
 Re: Re: 1965 4020 diesel fuel overconsumption in reply to JDJIM, 12-29-2001 19:12:22
Everything you could think of is new. It starts very good but lacks bottom power at high rev's. Bogs down very easy and doesn't want to pick back up unless you drop a gear or break the plow out of the ground. it is a non-turbo and its close to 7 gallons an hour when we are workin it! you better start lookin after 4 hours and make sure you don't run dry...
Ours used to be about 105 or so but not anymore.
It also doesn't smoke that much and it is smooth running but there isn't the umph like before and the fuel should be in the 7 or 8 hour range before refueling...
I appreciate the posts and responses from everyone and have tried to respond in kind to all. I will talk to my dad (75 years young!) and see what we can do. I and he knows he got fleeced but we needed the tractor (he took a while to pay them back) but there really isn't a lot of info to go into the dealer with. Now I have a lot and we shall see!
Thanks
Paul
JDJIM
12-30-2001 20:25:01
 Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Paul, 12-30-2001 11:58:19
First I must say I am not a professional mechanic or should say I've never worked for a sfop or dealership but I have been doing my own work and helping friends and neighbors work on cars trucks {Chevys} and Deeres mainly 4020's for a long time . I have been tractor pulling for 30+ years with Deeres mainly with a '64 4020 Power Shift Turbo you can probably guess by know I have done some things that genuine Deere people frown upon . Several of us have swapped ideas on 4020's for a long time . The 4020 I have now I bought 20 yrs ago with some scored pistons , I overhauled it using used parts I had laying around put M&W turbo and pan on it , later a 4840 cam and 4440 intake manifold plus bigger head in the inj pump . It is a chore tractor when not pulling in summer , mowing , spraying , spreading manure etc , I run it at 125hp and get it up to 220hp when pulling , I have seen it at 220 on a dyno but just for a minute or so , it wont last too long at that hp . A good 4020 non turbo stock pump leaf spring tight will put out 100-105 if it don't something is wrong . high idle 2450rpm pull down to 2200 {thats rated rpm} should be at 100-05 hp . should be some smoke not a lot but very noticable , pulled down another 50-100rpm should hang on and maybe gain a couple hp and little more smoke . That's on a good dyno prefferably an A&W with a honest operator . That is about all you will get out of a stock 4020 , stock rpm's. with no turbo . You can change leaf springs and put more fuel in but most of it goes up the stack you can't burn much more . I have seen and done this done many times . Enough for that , now on your 4020 , you had 105hp , that's pretty good , please don't take me wrong , the fuel system must have been in pretty good shape , what did they do ? I don't think the injectors could be the wrong size because most of the pencil injs are about the same , the ones for the 5020 are a little bigger but I don't think they fit in there . Pump timing ? Pump advance ? Have they been checked ? Transfer pump pressure ? Timing should be TDC with mark on flywheel and pump marks lined up , transfer pressure 70-75psi , all these get complicated to explain should have tech manual for injection systems to go by . Is the fuel return line , the line from the pump that connects to the top of injectors and then returns to top of fuel tank , open ? Was the camshaft taken out and put in out of time that was mentioned in an above post ? Just a few or I guess a lot of thoughts asto what might be wrong . Like you said the dealership is responsible only to rated hp and that is about it 91hp for a 4020 powershift , they say the tractor is at the rated hp and they might not do anymore about it . SAD isn't it , that's why I never go back after warranty work is done . I have many books , parts and tech and in my spare time I read and compare different things . I ran on too long , please keep me posted , I want to know what is happening . If you have any questions PLEASE feel free to ask , thanks for the time . JIM
Paul
12-30-2001 21:36:37
 Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to JDJIM, 12-30-2001 20:25:01
It was back in the shop 3 times, and i assume all that was checked. A guy with 35+years as a jd mechanic did the work and my dad (who has been an auto mechanic for 40+ years can talk to him straight and get straight answers.
Just wondering if some guys i have heard about have added 'special parts' to they're 4020's to get 130hp or just tuned it perfect. My dad is not convinced that a stock 4020 can be tuned to 130 hp (would be nice)!
We don't want to 'break' anything either, like the tranny, 3 point hitch etc.
How do you manage not to break the main chassis on yours running over 125hp?
Anything technical would be appreciated. We need to freeze our butts off this winter in the barn doing something productive!
My dad is generally a skeptic, so anything I tell him from this board he has kind of kept quiet about. But I understand what you guys are doing, I just need to get this hardcopied and have my dad read it.
Do you have a heavier 3point hitch for pulling so much?
My dad wants to get his fuel mileage and horsepower back. Money back would have been better. Farming is tough to get any money back but we love it!
and no you aren't rambling, i enjoy reading!
Thanks
Paul
JDJIM
12-31-2001 18:14:57
 Re: Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Paul, 12-30-2001 21:36:37
The leaf spring Don is talking about , is basically what controls the amount of fuel pumped , its setting is sometimes adjusted by shims under it , the more shims the less fuel and viceversa . Stock spring should be a 7-1 , with all shims removed and spring retaining screw tight , all else set up correctly you will come up with the 100-05hp seen it many times . I don't want to start an argument but I do not know where this 130hp is comming from supposedly stock . It surely can be done but I DO NOT recomend doing it for an everyday workhorse . Stock pump for a 4020 is a .330 head , means plungers are .330 thousandsth's diameter , two of them , should have the numbers 6-33 on the tag along with a lots of other letters & ### . I'm trying to make this as short and simple as possible but I'm not doing it am I ? Do you have the right pump ? I'm running a .370 head and I control the fuel [ HP ] with a " so called smoke screw " in the governor housing , that works good , but like I said some PROS frown on it . You gotta know what you are doing on that stuff though or you'll do damage . At 120 hp you will not hurt the power train on the old 4020 . On the Powershift trans make sure the system pressure is at high spec so things won't slip also adjust the shift valve to the fast side , it will jerk more but it wont slip as much between gears , the more slip the more the clutches wear . I've done all these things to my old girl plus a lot more , I'll leave my email call me if you have any more questions or post back on here , I've got nothing to hide I just want to see you get this tractor running as good as it should . I guess I just don't want to get in trouble for being on here too long . Thanks again for the time ,JIM 4chevys@ivnet.com
JDJIM
01-01-2002 03:54:07
 Re: Re: Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to JDJIM, 12-31-2001 18:14:57
Paul , my email adress is: 4chevys@ivnet.com I didn't post it correctly last night my typing skills leave a lot to be desired , JIM
Paul
12-31-2001 20:36:17
Thanks!
I'll get you on your email and no, you aren't taking up my time.
I appreciate it very much!
Paul
Chicken George
01-01-2002 06:53:43
 Re: Re: Re: Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Paul, 12-31-2001 20:36:17
Jd Jim,
Any information posted is soooo welcome !!!
maybe tomorrow I, or somebody elses problem will be solved by what you have said/learned I have only a 70 &730 yet I find this very informative. I have learned a lot so your windyness is not wasted!! this is so much better than reading about Politness mans dribble. This forun and others is sooo great and it is because of people wanting to help others with what they have learned the hard way , may God bless all of the contributers. And Paul,let us know what is found wrong with the 4020 Later and New Years greetings to all. Geo.
JDJIM
01-01-2002 11:39:41
 Re: Re: Re: Re: Re: Re: Re: Re: 1965 4020 diesel fuel overconsumption in reply to Chicken George, 01-01-2002 06:53:43
Chicken George: Thanks for the comment , like you said learning from mistakes , been there done that and I like to help others avoid mistakes from MISSINFOFMATION like I got several times . When I but a turbo on my firet 4020 in early '70's , not the tractor I have now , I was told a bunch of BU*******T guy told me why buy a 4630 when a 4020 can do the same . After 3 sets of scored pistons and worthless pump work , good thing it was a rainy spring because I had lots of days to work on it , by the way this all happened before I had 1200hrs on the tractor . I learned a lot about 4020's real fast and eventually traded for a 4630. From then on I am very careful who I listen to , read a lot and never advise anyone wrong because of what happened to me . I have tech manuals for all the Deere diesels 2 , 4, & 6 cyl pumps and injectors up to and incl 40 Series telling fuel settings etc , DEALERS wouldn't sell them to me , I had to buy them at closeout auctions etc . Study them a lot . I like working on the old 4020's and sure like working on problems like this , I WILL NOT lead anyone astray . JIM
G Taylor
01-01-2002 08:07:54
Paul I'm just up the 401 a ways too. Probably have drove past your places several times on the way to Windsor. We were a few minutes behind that terrible multi-vehicle wreck westbound 401 in Sept 99. I have to agree on HP as well. 1/4 HP per cubic inch displacemet at 1800 to 2000 rpm on a naturaly aspirated diesel is about max. Unless someone has improved volumetric efficiency beyond "stock". Judging by the fuel consumption there is already too much fuel flow through that engine. The problem(s) has to be one of those unusual but so obvious faults we can't see it for looking at it. Any chance those injectors were rebuilt & a metric/imperial conversion has them spraying at too low a pressure? As previously mentioned timing of injection & camshaft looks possible too. Even something as simple as a choked,twisted pinched hose connection or restriction somewhere between the air inlet & intake manifold. A plugged muffler with a baffle failure could do this too depending on the brand/design. We found a strange one the JD 4050 MFWD after smoke & poor starting was gradually worsening. A look at the engine showed the previous owner had already rebuilt the engine with less than 1500hrs. Oil analysis found silicon but the aircleaner was perfect. After much searching an airleak direct into the intake manifold at the optional ether start connection. The wee plug was never factory installed. We have some clay & hills in Huron County too. The are places where a 4-18" semi-mounted plough has her scratching for traction
Paul
01-01-2002 08:06:49
yes, learning is the name of the game!
I will keep you guys up to date.
Paul
