Clooney still back fire out carb
36 A
01-02-2002 16:44:47
Tried what you guys said all but pull starting.Still same thing.What i did notice was that it fires twice or so then fires a few out carb once or twice.So i the took mag off,the govener cover and plate on top of motor off.If i line dots from crank to cam the dots on top of cam to govener dont match?? What next?
Larry L. Walla
01-03-2002 06:19:02
 Re: Clooney still back fire out carb in reply to 36 A, 01-02-2002 16:44:47
You probably checked this, but just in case, did you check the tappet clearances? The lag on the mag is the most likely thing. You should not change that unless you are using a mag from a different model or year tractor. When a Two Banger doesan't run right for me, I always check the things I changed first, because it is usually my tnkering that makes it not want to work right.
Clooney
01-02-2002 17:03:30
~36A, don't worry about those dots, with the LH piston at TDC (lh impulse on the flywheel aligned with the mark on the case (3 o'clock behind flywheel) the flange on the R/H side of the governor that drives the mag should have the slots running parallel with the ground (running fore/aft. ~Where did the mag fire when you checked the spark at the l/h plug while turning the flywheel? The mag MUST fire the l/H plug when the flywheel "LH impulse" is lined up with the case mark. Once the L/H spark is timed to the LH impulse mark try pull starting it.
36 A
01-02-2002 19:01:38
 Re: Re: Clooney still back fire out carb in reply to Clooney, 01-02-2002 17:03:30
Yes my drive was parallel with ground.I had mag fireing a tad before cover.Only thing i changed was on the back of mag i loosened 4 screws and moved lug angle or trip so i could achive movement to get my flywheel to adj.on cover.As far as pulling i cant with on rear flat and snow, low gears i dought it will work.
36 A
01-02-2002 19:01:27
Clooney
01-03-2002 02:26:22
 Re: Re: Re: Clooney still back fire out carb in reply to 36 A, 01-02-2002 19:01:27
~36A, you shouldn't move the lag angle ring on the back of the mag as that changes the running timing. ~What model mag do you have & I will tell you where it belongs?
36 A
01-03-2002 16:05:11
 Re: Re: Re: Re: Clooney still back fire out carb in reply to Clooney, 01-03-2002 02:26:22
its a wico X xh 477 ser 265663.i moved it because it was all the way to the left. its at 1100 o clock now.
36 A
01-03-2002 17:33:26
 Re: Re: Re: Re: Re: Clooney still back fire out carb in reply to 36 A, 01-03-2002 16:05:11
going out to put everything back togher and try it. if it dont work ill pull it tommrow night after work. thanks for the help everbody.
Clooney
01-03-2002 16:48:58
~36A, for the Wico mag, set the impulse stop ring to have the witness mark on the stop ring 3-1/2 graduations left of the center mark, that will give you 30* running timing.(center is 12-1/2*)
~If you can't get the LH impulse on the flywheel to line up with the case mark when the mag snaps you will have to lift the governor & re-align the governor to cam gear so it will.
