1988 JD 2355 Steering Problem
chester from ke
01-02-2002 19:55:50
Have a 1988 JD 2355 late model haveing steering problems. The steering wheel will keep turning but the wheels steer very little. you have to steer very fast to get them to move. Does any one have a quick fix for this? thanks CHESTER
BrokenWrench
01-03-2002 16:07:15
 Re: 1988 JD 2355 Steering Problem in reply to chester from kentucky, 01-02-2002 19:55:50
Sorry to be the bearer of sad tidings but there is no guick fix for this. You have a cut or blown o-ring in the steering valve or a piece of dirt in the valve. You will have to pull the valve out and disassemble. get yourself a manual before you take it apart, (many small parts which must be kept in order) Good luck.
