John Deere 60 tapped holes in front
John Hicks
01-06-2002 15:29:13
This may seem like a stupid question, but here goes. I bought a model 60 a few weeks ago and noticed there are four tapped holes in the front, two above and two below the radiator screen. What are these for. In some pictures in a book there is nuts where these holes are. Thanks, John
Frank
01-06-2002 15:37:02
 Re: John Deere 60 tapped holes in front in reply to John Hicks, 01-06-2002 15:29:13
John:
These were mounting points for front mounted equipment, typically 2 and 4 row cultivators. I guess even a 6 row would have been available.
They're pretty stout, and over the years they've served all manner of contraption...I've seen them used for snowplow lift points, look-forward wagon backing hitches, and buzz-saws.
Frank
Don wisc
01-07-2002 10:08:12
 Re: Re: John Deere 60 tapped holes in front in reply to Frank, 01-06-2002 15:37:02
A lot .
of JD owners leave the cultivator bracket bolted to the lower set of holes. This is a L shaped bracket that the front of the cultivator set on.This can serve as a good hitch bracket to either pull the tractor or push wagons etc. also serves as a guard for the grill. These are usually avail at auctions or swap meets for a few dollars. Don
