Belt pully
36 A
01-06-2002 19:12:18
I got the old a running and the clutch is stuck.Took it apart and it must have held water for sometime because there is not anything worth using.Bolts are missing threads,clips for cover missing, drive disk is cracked 6 places.its junk.I can get one off newer tractor 46 and older will the hole thing interchange i mean everything
BobTGS
01-07-2002 07:52:29
 Re: Belt pully in reply to 36 A, 01-06-2002 19:12:18
I have used the mid40s A clutch pulley on an unstyled before ,but you should use a drive hub from an unstyled to keep the rotating assembly in balance.Ive put some of mine together with differant results.Try yours with the 46 clutch drive hub ,if the tractor vibrates, I can supply you with one for an unstyled(A19R).Bob,from Triple G Service,1-716-542-3175, 9am-8pm.
