Jd B cast rear wheels
Joe
01-08-2002 14:20:56
i have a 46 B with cast rear wheels. it is the solid piece cast wheel with no hub, just the 3 cast parts that are molded off the wheel. all 3 of those are broke off and being held on by the clamp. can this be welded or do i need i new wheel? if i need a new wheel, where is the closest junk yard from FARMINGTON,MISSOURI?
thanks,
joe
Clooney
01-08-2002 15:03:37
 Re: jd B cast rear wheels in reply to Joe, 01-08-2002 14:20:56
~Joe, I'm afraid the wheel wouldn't be worth repairing. Welding those ears back on would be difficult, expensive, hard to get them straight & the durability of the weld would be questionable.
~I'm afraid I can't help you on junk yards, you will need someone from your area to help you there.
jdman(MO)
01-08-2002 19:33:58
 Re: Re: jd B cast rear wheels in reply to Clooney, 01-08-2002 15:03:37
Probably 2 cyl Plus, Conway Mo, at least its big, down I-44. Maybe Mexico Mo, but she had a big sale and I don't know whats left. Russ
