2010 Transmission Lockup in Reverse
Richard
01-09-2002 19:38:33
This tractor has been a loyal machine, but has been locking up increasingly in first and third reverse under a snowplowing load. The lockup feels the same as hard brake action, with increasing laboring of the engine, and this is where I give it the clutch. When I let the clutch back out, there's no problem for a while. Doesn't seem to have anything to do with the brakes.
I don't want to hurt the old beast if there's something I can easily fix like a shifter or linkage. For anyone who knows this old iron, I'd appreciate your pointers on whether there's an easy fix or I should plan to open it up.
Thanks for any help you can give,
Richard
jack
07-20-2003 14:44:50
 Re: 2010 Transmission Lockup in Reverse in reply to Richard, 01-09-2002 19:38:33
when taking trans out of raverse it sometimes stayes in reverse and is locked in two gears.i have checked the linkage and its right on. i tried
adjusting the linkage one turn at a time each way
and it is worse. can you tell me whats wrong.
camrod69
07-12-2005 19:56:37
 Re: Re: 2010 Transmission Lockup in Reverse in reply to jack, 07-20-2003 14:44:50
I don"t have any technical knowledge about this question, but I have a 1966 model 2010 crawler dozer and need to know what type of transmission fluid to use in it. Any help with this would be greatly appreciated.
john
