1940 JD H How Hot is Too Hot ??
Rich
01-10-2002 18:18:31
I have a 1940 John Deere "H" how hot can you run them before damage and if so what could the damage be ? Thanks for any imput.
Will P
01-11-2002 13:11:12
 Re: 1940 JD H How Hot is Too Hot ?? in reply to Rich, 01-10-2002 18:18:31
How hot is it getting? I have had my 43B to about 225 under a load (2-16"plow). All fuel tractors use to have to get over 200 to burn distilate. So they use to get very hot.
Will P
Rich
01-11-2002 20:16:37
 Re: Re: 1940 JD H How Hot is Too Hot ?? in reply to Will P, 01-11-2002 13:11:12
Will,
I am building a scale model JD "D" 39 inches tall. I am using a JD "H" motor and tranny. In order to reduce size I had to use a smaller radiator along with the pipes into and out of the radiator. At high idle inside the 70 degree shop it works ok. As soon as I finish the front axle I can take outside and put it under load. I would hope to keep it under 225. What usually goes if the engine is run too hot? Thanks Rich
Will P
01-11-2002 21:00:09
 Re: Re: Re: 1940 JD H How Hot is Too Hot ?? in reply to Rich, 01-11-2002 20:16:37
Your project sounds cool. Don't know what whould go first. One thing for sure is, If I run 50/50 water antifreeze, 225 is were my B runs. Put straight water in she won't go over 200. Antifreeze is a oil and does not cool as well as water and it slows the thermosyphen system down. I didn't like my B running 225 degrees. But alot of the old times that I talk to didn't worry about it getting that high. Just make sure you have good oil presure and don't go over 225 and I think you would be ok. Let me know what she runs with a load on her. Sound cool!
Will P
