John Deere 60 intermitant backfire
John Hicks
01-16-2002 21:02:12
My 60 backfires every once in awhile at medium to slow rpms. There is some small exhaust leaks in the ehaust pipe. Could this be causing this?
Clooney
01-17-2002 15:56:34
 Re: John Deere 60 intermitant backfire in reply to John Hicks, 01-16-2002 21:02:12
John, yes, an air leak into the exhaust system can & often will result in popping & firing in the muffler as it allows the remaining fuel in the exhaust to ignite. This usually happens at idle when the mixture is richer & incompletely burned & on overrun/decel when the throttle is closed & the vacuum is high resulting in not enough air entering the low pressure side of the carb to mix with the fuel being pulled from the idle #1 orifice..
John Hicks
01-17-2002 18:27:45
 Re: Re: John Deere 60 intermitant backfire in reply to Clooney, 01-17-2002 15:56:34
Thanks for the info
Joe
01-17-2002 15:44:13
your carb settings are off. an exhaust leak wouldnt make any difference at all.
