2020 Brakes
Mark
01-19-2002 16:06:18
There is no brake on the right side. Tried bleeding the brakes & no fluid will come out the right side. But when you shut it off, pump it 3 times then there are brakes there. It then bleeds off. Any suggestions on how to fix?
Brokenwrench
01-20-2002 15:41:37
 Re: 2020 Brakes in reply to Mark, 01-19-2002 16:06:18
It could be the master cylinder or the brake housing. An easy way to test this is to switch the lines on the back of the master cylinder. ie left cyl to right brake . When hooked up this way try bleeding the brakes again. If your right pedal pumps up and holds and the left pedal won't pump up, then the right brake housing is the culprit. If the left pedal pumps up and holds but the right one doesn't then the right half of the master cylinder is bad. After repairing don't forget to hook them up correctly. Hopes this helps.
