I cant believe i saw this!!
joe
01-20-2002 16:17:36
i saw a john deere G yesterday in missouri with a ford V-8!!!!! the owner was snow plowing his drive way. it looked like a puller. it had really wide tires and was all funky looking in the tranny area. i never seen such a thing!!!!!
JOE
scotty b
01-20-2002 16:25:41
 Re: i cant believe i saw this!! in reply to joe, 01-20-2002 16:17:36
I know a guy here in oklahoma that has a F'20 farmall with a v-8 out of an old packard. He brings it to the antique pulls sometimes just to play around. Pretty unique I guess.
Ron
01-20-2002 20:42:15
 Re: Re: i cant believe i saw this!! in reply to scotty b, 01-20-2002 16:25:41
We have a fella here in central Ohio who makes a kit..... His "A" has a 350 Olds V-8 Diesel in it, and he claims it will pull 5-14" plows....!! he drives it in parades...it still uses the original Hand Clutch..... Looks good--a real Mind-Bender...!!
Ray
01-21-2002 20:17:36
 Re: Re: Re: i cant believe i saw this!! in reply to Ron, 01-20-2002 20:42:15
How does the V8 sit in the tractor? Does the crank shaft line up with the tractor? How did he connect the engine to the transimssion?
Ron
01-21-2002 20:50:35
 Re: Re: Re: Re: i cant believe i saw this!! in reply to Ray, 01-21-2002 20:17:36
The engine sits facing forward...he replaces the Crankshaft with a machined shaft that has a ring gear on it...the engine turns the pinion shaft... It uses the original John Deere clutch.... he runs it in several parades around here.... Ostrander, Ohio.. Delaware Ohio... With the diesel, he doesent have to have any governor... Looks Great, with 4 exhausts on each side.!! Motor is right back, Bellhousing against the John Deere crankcase...
G Taylor
01-22-2002 07:37:46
 Re: Re: Re: Re: Re: i cant believe i saw this!! in reply to Ron, 01-21-2002 20:50:35
I wonder what he uses to handle the thrust on the crankshaft with the pinion gear?
Brian
01-21-2002 18:52:45
Where in Central Ohio can I see this beast in a parade? I live between Columbus and Lancaster.
Brian
Ron
01-21-2002 21:15:18
 Re: Re: Re: Re: i cant believe i saw this!! in reply to Brian, 01-21-2002 18:52:45
He had it in the 4th of July Parade in Ostrandor, Ohio the last 3 years... It was at the Delaware County fair--last year. It was in the lot by the Jr Fair building, with all the other old tractors and hit and Miss engines.. The thing DOES Blow your Mind..!!!!
R L Armstrong
01-26-2002 16:45:53
 Re: Re: Re: Re: Re: i cant believe i saw this!! in reply to Ron, 01-21-2002 21:15:18
Some people just have too much time on their hands. More power to them. RLA
